Forum / Freizeit
BUY K2 LIQUID SPRAY ONLINE Threema ID_ZX6ZM8UN
Larosso - 36
Dabei seit 11.2023
108 Beiträge
Geschrieben am: 22.11.2023 um 16:06 Uhr
K2 liquid Spray is a kind of synthetic cannabinoid that is also known as Spice.
They're made from dried plant materials that have been sprayed with mind-altering chemicals.
But though k2 Spice products may contain dried plants (like tea leaves), what makes them a drug are the synthetic (man-made) chemicals the plant material is coated with.
These synthetic drugs were first designed by scientists to use in research.
https://buy-5cladba-5fmda-online.com/product-category/liquid-incence/
Once the production methods were published in scientific journals for others to see, enterprising drug manufacturers used the directions to make illicit drugs they could sell.
WHAT IS THE STRONGEST K2 LIQUID?
K2 E- LIQUID CODE RED 5ML. K2 e-liquid CODE RED. Experience the ultimate euphoria with the high popularity K2 e- liquid Code Red.
This blend is the strongest e- liquid ever created, it is powerful enough to enhance your mood and boost your energy with a single drop.
Synthetic cannabinoids
Although often referred to simply as synthetic cannabinoids, many of the substances are not structurally related to the so-called 'classical' cannabinoids, ie compounds, like THC, based on dibenzopyran.
The cannabinoid receptor agonists form a diverse group, but most are lipid-soluble and non-polar, and consist of 22 to 26 carbon atoms; they would, therefore, be expected to volatilize readily when smoked.
A common structural feature is a side-chain, where optimal activity requires more than four and up to nine saturated carbon atoms.
Synthetic cannabinoids fall into seven major structural groups
Naphthoylindoles (eg JWH-018, JWH-073, and JWH-398).
Naphthylmethylindoles.
Naphthoylpyrroles.
Naphthylmethylindenes.
Phenylacetylindoles (ie benzoylindoles, eg JWH-250).
Cyclohexylphenols (eg CP 47,497 and homologues of CP 47,497).
Classical cannabinoids (eg HU-210).
CAN YOU VAPE K2?
Yes, it is possible because the drug can also be found in a liquid form. so it can be vaporized and inhaled through that method. This is commonly done with vaporizers and e-cigarettes.
https://buy-5cladba-5fmda-online.com/product/k2-liquid-spray/
Threema ID_ZX6ZM8UN
WhatsApp & Skype _ +1 601-207-3026
Wickr_ Cannabinoids71
Telegram & Signal_+1 601-207-3026
Forum / Freizeit
