Setup HP printer through 123.hp.com/setup
hennry021 - 35
Dabei seit 08.2022
Geschrieben am: 13.08.2022 um 21:56 Uhr
Zuletzt editiert am: 13.08.2022 um 21:59 Uhr
• Unpack the HP printer box, and then lift the printer carefully.
• You can now proceed with the basic connection setup by using the https://123-hp-printer.com/
to set up the initial printer setup.
• Use the compatible system to connect the printer using a proper port connection between the printer's backside and the socket.
• Turn ON the printer you wish to use and place the paper sheets in the input tray. Adjust the guide to avoid paper jams and other troubleshooting issues.
• Next, place the ink cartridges in their respective slots.
• Check the basics of the printer, and then change the start-up settings for the HP printer.
• The HP Official Page has the latest HP Printer driver software. Download and install it. You can verify the driver setup by using the Windows settings> Devices> Printers & Scanners.
hennry021, ... mehr anzeigen
